No cruise control
Old Apr 9, 2006 | 07:35 PM
alollich's Avatar
Question Need more help, No cruise control
I have lost use of my cruise control. It worked fine and just quit one day. I checked the fuse and it is fine. I pulled the steering wheel off and the contacts were dirty, but looked all right, this is a 88 so no clockspring. The buttons on the steering wheel fell the same as when it worked, no mushy buttons or anything. The master cylinder has been replaced. There are not any shorts as far as I can tell. Anybody got any other suggestions? I checked the search function, but there was not much there.
Old Apr 9, 2006 | 08:07 PM
PKRWUD's Avatar
Was the master cylinder replaced before or after the cruise control stopped working?
Old Apr 10, 2006 | 11:07 AM
AaronNichols's Avatar
might be the stop sensor switch on the end of the master cylinder. that's what the recall was all about and that's what stopped my 95 from working
Old Apr 10, 2006 | 04:54 PM
alollich's Avatar
I think it was about the same time. The master was leaking internally down the booster. If I remember right the cruise stooped shortly before I replaced the master.
Old Apr 17, 2006 | 08:14 PM
alollich's Avatar
I checked everything again and it either has to be the buttons on the wheel or the switch on master cylinder. Is the switch in the resivor? Is it a dealer only part? Thanks
Old Apr 19, 2006 | 01:19 PM
Droog's Avatar
I had this exact problem and here's what fixed it:
Took it to dealer, they first tested three sensors that need to be okay for cruise to work. One was in the shifter, one under the hood, and I think the other might be near the brake pedal ( Could be wrong on that one. )
If that didn't solve your problem, ( like me ) they then test the Computer and found that where the cruise signal came into the computer, it lost its brain or something. Had the whole computer wiped and reprogrammed, and presto, perfectly working cruise.
Old Apr 23, 2006 | 06:30 PM
alollich's Avatar
Just an update. Cruise has been fixed. Something I should have checked first, but overlooked. The linkage had become seperated from the throttle body. Hooked it back up and everthing works.
