towing
Old Mar 21, 2006 | 01:01 PM
stewdaddy76's Avatar
towing
going to be towing a tow dolly with a 99 mazda Pro 4 door
w/ a 1995 ext cab, long bed, 4X4,dual tank, 5.0L , heavy duty rear end springs, stock 235/R15 tires w/ 3.31 gears in the rear.(112,000 miles)
adding on
shorty headers
high flow catco cat Y pipe
cat back dual dear exit
MSD cap and rotor
MSD 48,0000 coil
8.2mm plug wires
K&N filter(in stock air box w/ bottom cut off)
B&M shift kit for the E4AOD
what else can i do to help besides going to 3.55 or up gears
and yes i knoe thw 351 would be better but i only paid $3,000 and truck is in show room cond.
thanks for the help
stew
Old Mar 21, 2006 | 02:12 PM
StrangeRanger's Avatar
Auxiliary tranny cooler.
and if none of those work:
Old Mar 21, 2006 | 02:24 PM
towing
truck came with the one from the factory. 8 blade i think
Old Mar 21, 2006 | 03:42 PM
adrianspeeder's Avatar
Thats nice!
Add an aux cooler
Adrianspeeder
Old Mar 21, 2006 | 05:54 PM
towing
should i go up to 3.55 or will the 3.31 gears do fine even if a bit slow going up hills?
Old Mar 21, 2006 | 05:55 PM
going to put in a tach and oil/trans/water temp gauges too.
Old Mar 21, 2006 | 06:30 PM
Clifford f150's Avatar
I second the tranny cooler.
And make sure your brakes and tires are in good shape.
Personally, I would get lower gears and not bother with most of the rest of what you've got listed. Lowering the gears makes everything not work quite as hard, and the 302 is ok with revving a little.
Old Mar 21, 2006 | 06:44 PM
While you're plumbing in the aux. tranny cooler, you might want to consider a remote tranny filter like the units from Perma-Cool They increase both cooling and filtration and give you a convenient place to mount the sender for the tranny temperature gage. It will save you from having to drill and tap the side of your deep sump aluminum tranny pan
If you think i'm obsessing about heat you're right. Nothing, absolutely nothing, kills a tranny faster than getting it too hot and towing adds a lot of excess heat which you have to get rid of somehow. I've added all of the above to my E4OD so I'm not just blowing smoke
Old Mar 22, 2006 | 02:20 PM
towing
thanks for the help, if you have any more info please post it.
also if any one knows of a good place in san diego to get work done let me know right now it's at $650 for rebuild w/ 3.55s but i can get the parts off line for 240 and can't see paying all the rest for labor.
and now i just found out that I would have to do the front gears too. did not know that. found out from the guys at Brendspeed(very helpfull and on e-bay)574-834-7455. so i'll just go slow and add another cooler.
