cold air intake help please
Old Mar 19, 2006 | 10:16 PM
lind's Avatar
Hi guys
I have a 95 f150 ext cab with a 5.0 89.800 miles on runs great
Just seeing a lot about the cold air intakes
Suppose to improve gas millage hp tq ect.
Now the only one I have seen for the 95 5.0 is a k&n
type But all it looks like is a Round filter,,TAHT IS IT
FOR WHAT 150 bucks
Most of what I have seen have the Tube and Heat sheilds ect ect
The pt # for thek&n is 572503
has anyone got a diff or same set up??
If so I would like your thought on how they work Like they claim they do..
And some thougts on throt bod spacers as well
Thank u soo much
I know its it a lot of ?'s
David
Old Mar 19, 2006 | 11:04 PM
StrangeRanger's Avatar
Is your 95 MAF or S/D?
Old Mar 20, 2006 | 12:58 AM
PKRWUD's Avatar
The K&N FIPK works wonders in my '95, but I have a 4.9L. Those with V8's have consistantly reported less than total satisfaction with them.
Old Mar 20, 2006 | 03:38 PM
TheGrayt1's Avatar
The cold air intakes for the 5.0's will work with the 4.9? sorry not trying to hi-jack the thread.
Old Mar 21, 2006 | 07:33 AM
PKRWUD's Avatar
Yup. Same part numbers and everything (at least for the K&N FIPK).
Old Mar 21, 2006 | 09:16 AM
Yes and no.
The Gen II kits which replace the airbox and intake tube and have the heat shield, etc. are V-8 specific. Possibly they could be adapted to the 4.9, but given the different location/orientation of the T/B it would take some work. The standard FIPK replaces the air box and fits either engine.
Old Mar 21, 2006 | 10:09 AM
PKRWUD's Avatar
Originally Posted by StrangeRanger
Yes and no.
You'd be a good person to ask: Just out of curiosity, do you know what the outside diameter is of the two TB ports for the 5.0, or what the inside diameter of the air intake hoses are for the same? i want to get rid of the factory air tubes on my 4.9L because they're ribbed, and I'm looking for the most economical method.
Old Mar 21, 2006 | 11:09 AM
I just happen to have a spare 5.0 T/B lying around for future use.
I'm pretty sure the horns are the same OD, but I'll measure tonight and post.
I can't measure the 300 T/B at the moment, it's not at home, so you'll have to get the other half of the comparison on your own.
Old Mar 21, 2006 | 11:15 AM
PKRWUD's Avatar
Excellent! The 4.9L 'horns' are 1 15/16".
You don't happen to have an extra set of V8 air intake tubes lying around as well, do you?
Old Mar 21, 2006 | 02:52 PM
daniel3312's Avatar
From: Osceola Arkansas (50 Miles North From Memphis TN)
Hey man i happened to see an air box and tubes on ebay the other day for like 8 dollars and the shipping was more than resonable too.......
Old Mar 21, 2006 | 03:18 PM
PKRWUD's Avatar
You wouldn't happen to remember what the auction title was, do you? I've spent an hour or two on eBay looking, but it's easy to miss something if you don't use the right words when searching.
Old Mar 21, 2006 | 06:01 PM
The V8 T/B is 2-9/32" OD right behind the beaded edge of the horn where the hose rides on the horn surface.
Old Mar 21, 2006 | 06:49 PM
PKRWUD's Avatar
That means the V8's are 11/32" larger. That's significant enough to mean that using the V8 hoses wouldn't be a wise idea. Looks like this needs to be a homemade item. Joy.
Thanks!
Old Mar 21, 2006 | 07:15 PM
daniel3312's Avatar
Sorry man i guess it's already ended i couldnt find it again either. Now on my 1992 ford it had slightly different hoses on the same air box they're designed different however i dont know if it makes a difference of the hose size?
Old Mar 21, 2006 | 09:33 PM
PKRWUD's Avatar
Thank for trying!
