master cilyner now slave cilyner??
Old Feb 18, 2006 | 11:16 AM
Garbar's Avatar
hey guys well i just had the master cilynder replaced . i must add just before this the problem was the clutch having no pressure so i had to replace the master ' then about a week later it did it again ' the clutch has no pressure what so ever. this is really beginning to f#$%ken eek me off, now there is noticable fluid underneath the transmission and seems to becomming outta the little plug located on the tranny and the front part of the tranny but if there is fluid leeking from the transmission what kinda fluid is it' brake fluid? cause if its brake fluid from the master i checked it and it seems to be ok or maybe its leeking slowly? i had posted about this before and adrianspeeder said he would put $10 down that it was the slave , well if thats the case ill need your mailing adress. https://www.f150online.com/forums/sh...d.php?t=227652
Old Feb 19, 2006 | 02:01 PM
Ford4ever's Avatar
Sounds like a leaky slave, its a pretty cheap part but you have to pull the trans out to change it.
-Jon
Old Feb 19, 2006 | 03:07 PM
adrianspeeder's Avatar
It's alright man slaves go commonly so it's a safe bet to make...
I also recommend a Centerforce I clutch while your down there.
Adrianspeeder
Old Feb 19, 2006 | 04:02 PM
Garbar's Avatar
yup the only downside is that i dont have an airgun to remove the bolts that are in hard to get locations i tryed to remove them lastnight i ended up getting 3 of the 8 bolts that are attatched to the braket that holds up the tranny the rest of thenm are just to tight to take off but i also got the clutch mastercilynder cable off with that. well its my birthday and i got AMA a towtruck service for a year for my birthday and i think ill use it and have them tow it down there for a fix' any idea how much this job will set me back and others that i should have changed while the tranny is out. thansk for your repiles.
