pointers wanted...
Old Feb 17, 2006 | 09:21 PM
fordman5's Avatar
Arrow pointers wanted...
i have a 90 f-150 4x4.. does anyone have any pointers on droping the tranny? do i need to drop it, or can i just un bolt it, and slide it back? do i need to take the transfer case off the tranny before i drop it?
thanks alot
Old Feb 17, 2006 | 09:48 PM
zapster's Avatar
from what your trying to say is you need to put a clutch in it...correct?
...zap!
Old Feb 17, 2006 | 10:09 PM
fordman5's Avatar
yeah, sorry, i should have clearified that. :-/
Old Feb 18, 2006 | 11:48 AM
fordman5's Avatar
come on guys.. i have to do this today...
Old Feb 18, 2006 | 02:32 PM
Garbar's Avatar
Yea me 2 ' but im going to give it a go' right now i got to take out my tranny so basicly disconnect your drive shaft then go after the bolts that are holding your tranny ' then there should be a braket in there thats also holding up your tranny this should still hold it up after all the bolts are undone' now the mastercilynder cable on the tranny should be taken off ' these tend to be a pain to take off but i used a screw driver to pry the piece up and then disconnect it' after its disconnected shake the tranny to make sure its loose and check for bolts that might still be on the tranny. Once thats all done grab a good jack and jack up the tranny then remove your braket and bring down the transmission ' this is how i took out my tranny for the first time but now i got to go in there and check the slave cilynder such a pain in the a$$. oh and check to see if its disconnected from your starter good luck
Old Feb 19, 2006 | 12:40 AM
fordman5's Avatar
cool, thanks for the tips.
I have already unbolted the bell housing from the block. and disconected the 4x4/2x2 selector. do you guys think i can get away with not disconecting the transfer case, and just sliding the traney/ transfer case backwords?
thanks for the help
Old Feb 28, 2006 | 03:28 PM
Corpsie's Avatar
thanks for the help
How's this going for you? I may need to do it soon and will probably have to harass you for tips.
Old Mar 2, 2006 | 12:23 AM
fordman5's Avatar
it went great. it wasnt to bad to replace. my e-mail is gregs68mustang@inbox.com
feel free to e-mail me if you have any problems. as im not on this site much
