A/c compressor???..
Old Feb 8, 2006 | 09:14 PM
gander's Avatar
A/c compressor???..
Ive got one heck of a racket coming off my a/c compressor{I pretty sure} is this possibly the clutch or the compressor itself? ..what I was considering doing was trying to remove compressor and locating a belt that I could use and bypass it until time, motivation, and funds allow...any thoughts on this will be appreciated....ie getting a belt that would work etc...I have a 1996 f150 with the 4.9 six.....Thanks
Old Feb 9, 2006 | 12:21 AM
Clifford f150's Avatar
If you bypass, your defroster won't work as well for defogging the windshield. Don't know if that's an issue there in TX, it's not here 114+ days of no rain, but it bears mentioning.
Also the refrigerant is a lubricant-- so again if you do bypass make sure to handle it sooner rather than later because the compressor will dry up and you may have a seized compressor if you wait too long.
Now, as to whether it's the clutch or the compressor, a couple of questions-- is the noise constant or on-again off again? Can you describe the noise? Does your AC work currently?
Also if you're not sure it's the AC at all, sometimes a length of hose used like a stethoscope can pinpoint the noise source.
Old Feb 9, 2006 | 01:05 AM
Ford4ever's Avatar
Usually its the bearings in the front of the compressor that go bad and cause it to make noise all the time whether the a/c is on or not. If you ignore it the bearings will seize and your belt will break.
If you want to bypass the compressor just go to the parts store and ask them for a belt for your truck but tell them it doesn't have a/c. I did this a few months ago on a 95 f-150 with a 4.9l for a customer who couldn't afford for me to replace or rebuild the compressor.
-Jon
Old Feb 9, 2006 | 07:17 AM
gander's Avatar
re a/c compressor..
The a/c does still work ...noise is fairly constant but appears to get worse when a/c is turned on....If I do try to go with shorter belt for awhile Will I need to pull whole compressor or can the clutch just be pulled off without removing compressor
