ABS Problems
Old Feb 3, 2006 | 04:56 PM
iroczman87's Avatar
ABS Problems
My ABS light comes on at exactly 15mph. I had my mechanic check the codes on the computer and it gives a code 10, 11 and 12. His book says to take to dealer for these codes. Does anyone know what these codes mean?
Thanks, Tim
Old Feb 3, 2006 | 06:03 PM
iroczman87's Avatar
I found these codes in the forum. Does anyone know if they apply to a 1995 also? If so what is # 10 and # 11 ???
# of Flashes Problem
2: Open RABS II Isolation Solenoid Circuit
3: Open RABS II Dump Solenoid Circuit
4: Open/Grounded RABS Valve Reset Circuit
5: Excessive Dump Solenoid Activity
6: Erratic Rear Anti-Lock Brake Sensor Circuit
7: No Isolation Solenoid During Self-Check
8: No Dump Solenoid During Self-Check
9: High Speed Sensor Resistance
10: Low Speed Sensor Resistance
11: Brake Pedal Position (BPP) Switch Closed
12: Loss of Brake Fluid During an Anti-Lock Stop
13: RABS II Module Failure
16: RABS System OK
Old Feb 6, 2006 | 06:53 PM
iroczman87's Avatar
Well, I changed the sensor in the diff. Light still comes on ay exactly 15mph. Any ideas folks?
Old Feb 6, 2006 | 07:35 PM
adrianspeeder's Avatar
Could also be the tone ring in the diff that the speed sensor reads from.
Adrianspeeder
Old Feb 7, 2006 | 08:53 AM
projectSHO89's Avatar
Start with the 11:
From the Service CD:
Code 11 is caused by the stoplight switch always being closed prior to the vehicle moving. If the stoplight switch remains closed when the vehicle begins to move, the REAR ABS warning light will turn on at approximately 16 mph. Code 11 will not be latched in the control modules memory until the speed of the vehicle exceeds 37 mph for at least 10 seconds. If the vehicle does not exceed 37 mph for at least 10 seconds, then the REAR ABS warning light will turn on but the anti-lock electronic control unit will not latch a code. Code 11 can be caused by a driver resting his foot on the brake pedal with just enough pressure to close the stoplight switch, while driving at least 37 mph for a minimum of ten seconds. When this occurs, a Code 11 will be latched by the anti-lock electronic control unit.
Maybe your brake lights are staying on. That will certainly cause this problem.
Steve
