Looking for an after market fuel tank replacement
Old Jan 30, 2006 | 07:49 PM
mkmoren's Avatar
Question Looking for an after market fuel tank replacement
I have a 1994 F-150 4x4 with the 5.0 and E4OD transmission. This is a regular cab truck. The forward driver's side fuel tank has a leak. This tank for this engine, wheelbase, transmission, and cab configuration is a 17 gallon tank. I can't find an aftermarket anywhere and the factory tank is nearly $400. I would appreciate any help with a recommendation for a tank location of the aftermarkets in the $100 range. Any part # and seller information would be appreciated.
Mike
Old Jan 30, 2006 | 08:23 PM
fordtough_k_w's Avatar
try www.lmctruck.com, get a free catolog, im pretty sure they will have what ur looking for
even if they dont this catolog will only do you good since you can find almost every part imaginable
Old Jan 30, 2006 | 08:35 PM
adrianspeeder's Avatar
Got a bronco tank from LMC.
Adrianspeeder
Old Jan 30, 2006 | 09:30 PM
Ford393's Avatar
tank
Got a 32gl tank from Advance Auto 2-3 years back for 180 and change. Or was it pepboys
Old Jan 31, 2006 | 08:29 PM
Ford393's Avatar
Ford393<--------------Detroit.......... moved out of Detroit about 1976
Old Feb 1, 2006 | 07:27 PM
SnapB75's Avatar
Try.......www.mtscompany.com
Old Feb 3, 2006 | 06:09 PM
iroczman87's Avatar
I have a 95 reg cab short bed 4x4, apparently these tanks are hard to find. You can contact my friend who replaced mine with an aftermarket if you wish. It was around 400 with pump and sending unit.
Stones Automotive
Horn Lake, MS
Tim Stone
662-280-7248
