Removing steering wheel
Old Nov 22, 2005 | 01:34 PM
buck8's Avatar
My ignition cylinder won't make the last turn to 'Start' on my column - it's bound up. I removed the switch from the column and tried to pull the linkage to the last increment but it won't budge (I start it with an allen wrench...) I want to remove the steering wheel to see what's binding it. Any tricks other than getting a steering wheel puller to get the wheel off. And, once I'm in, is there anything I can do to the gears - is another column the answer?
I have tilt.
Old Nov 24, 2005 | 01:01 PM
Ford4ever's Avatar
Usually if you wiggle them side to side a little and pull real hard the steering wheel will pop off, otherwise you have to use a puller.
-Jon
Old Nov 25, 2005 | 12:15 PM
buck8's Avatar
Thanks for the reply
Thanks jon,
Actually, a rental from Autozone is only $15. I'm gonna try that route first. with my luck I'll mess something up trying to wiggle it.
Buck
