bird chirping dash
Old Nov 14, 2005 | 09:06 AM
juniorhawk's Avatar
bird chirping dash
Lately I have grown weary at listening to the constant chirp/chatter/rattle of the dashboard on my F150. It sounds like a bunch of little, sqeaking canarys under there and it is beginning to drive me insane in all honesty.
Is there a specific place I can look and try to disassemble the thing? I really would appreciate it if anyone has had this issue, to let me know how they dealt with the problem.
Thanks,
Erik
Old Nov 14, 2005 | 12:21 PM
adrianspeeder's Avatar
Common problem for the dash mounts to break. Does the whole dash move if you hit a bump or can you push it around?
Adrianspeeder
Old Nov 14, 2005 | 08:06 PM
bmx150's Avatar
my 1995 150 does the same and can be moved around and jumps from bumps
Old Nov 16, 2005 | 04:05 AM
PKRWUD's Avatar
There is a large amount of styrofoam used in your dash assembly, and if anything breaks, squeaking is unavoidable. Good luck.
Old Mar 16, 2007 | 08:44 PM
Blue moon's Avatar
Yea I have a little birdy in my dash also, comes from the passenger side, I tighted the 7mm bolts, still rattles, It's driving me crazy...
Old Mar 16, 2007 | 09:58 PM
usedtodrivechev's Avatar
cheap dashboards. get used to it.
Old Mar 17, 2007 | 12:22 AM
Steve83's Avatar
There are 2 TSBs for dash noise: one referrs to the R end mounting tab breaking off, and how to install the updated steel tab, but all '95-up got the steel tab from the factory. The 2nd referrs to the plastic dash shell rubbing on the steel A-pillars. Pull your A-pillar trim & notch/break/cut/drill out just enough of the dash shell that it can't touch. Make sure you don't cut so much that the trim won't cover your work.
Originally Posted by PKRWUD
There is a large amount of styrofoam used in your dash assembly...
HUH??? I've taken several '92-96 dashes out & apart, and I don't remember even a SMALL piece of styrofoam in any of them. None in ANY Ford dash I've removed.
Old Mar 18, 2007 | 09:21 PM
Blue moon's Avatar
Steve is right, I pulled my a-pillar off tonite, there is just a tiny bit of plastic rubbing at the corner, that little edge makes a lot of noise, but, not anymore...
Old Mar 19, 2007 | 11:37 PM
PKRWUD's Avatar
LOL! Heh, that was supposed to be funny. It was a year and a half ago, it seemed funny to me at the time.
My sense of humor isn't always top notch, or so I've been told. lol.
See, that was supposed to be funny, too.
Old Mar 20, 2007 | 08:37 PM
Blue moon's Avatar
That's the beauty of these forums, even though its an old thread, there are people out there with the same problems, with this site, we can overcome those obstacles
Old Mar 20, 2007 | 10:32 PM
Bruce R Leech's Avatar
Steve I think you should make a sticky out of this. you have saved more peple from going crazy than any other thread.
I fixed mine thanks to Steve.
Bruce
Old Mar 20, 2007 | 10:37 PM
i just turn up the radio.
Old Mar 21, 2007 | 06:50 AM
Radio don't work in the '92
Old Mar 21, 2007 | 10:56 PM
Steve83's Avatar
I'm not an administrator here or on any other BBS. I can't make anything a sticky. But my signature link will take you to more info than you can digest in a week of solid reading.
Old Mar 22, 2007 | 12:06 AM
Steve your signature link is fast becoming my Bible.
Bruce
