Location of ECM in 94 F150?
Old Nov 12, 2005 | 11:26 PM
jbailer's Avatar
Can someone tell me where the ECM is in the 94 F150 w/302. If it makes a difference, mine is fuel injected and has a MAF. I'm also trying to figure out which one is in my truck. I've heard it could be a IV or a V (OBD2). I read somewhere the location was the drivers kick panel but I couldn't see it. -Joe
Old Nov 13, 2005 | 02:03 AM
adrianspeeder's Avatar
It is OBD1 with the computer up above the parking brake pedal behind the kickpanel.
Adrianspeeder
Old Nov 13, 2005 | 04:12 AM
PKRWUD's Avatar
To remove it, you need to remove the kick panel, and the e-brake assembly (3 nuts). You can access the ECM's 60 pin connector from the engine compartment. It sits about 8 inches below the master cylinder.
Old Nov 13, 2005 | 12:19 PM
jbailer's Avatar
Thanks guys! I finally found it. Actually I never did see it from inside the truck. I found it (the connector) in the engine compartment, slightly below and about 10" to the right of the brake master cylinder. I was trying to get the identifying code off of the sticker on the connector. It is in fact an EEC-IV (OBD1). The code didn't match up to anything I've found on the Internet yet "HOG0". I lookedd for the actual computer but couldn't see it from the passenger compartment or engine, only the connector... From the passenger compartment, I looked where it would come through the firewall but couldn't see it. The only thing around there was a fat white rectangular connector maybe 1.75" wide by about 3.5" tall. -Joe
Old Nov 13, 2005 | 12:37 PM
PKRWUD's Avatar
Okay, I'll try this one more time. You have to remove the drivers side kick panel, and then the parking brake assembly in order to get to the ECM from inside. You can't even see it until you remove those two items. Once you do, you will see a little metal plate that covers an access port on the ECM. The true code will be on a decal on that little plate.
