need more amps
Old Nov 4, 2005 | 08:11 PM
Unlawful's Avatar
Registered User
need more amps
my 96 F150XL has a 95 amp alternator, Is there a higher amp alternator on the XLT or Lariet models?
Old Nov 4, 2005 | 08:20 PM
adrianspeeder's Avatar
"You want more amps? YOU CAN'T HANDLE MORE AMPS..."
lol
What you wanna do is the 3G swap. Basicly bolt on, it is the install of the alt from a tauris which should get you about 130amps.
Here is a pictorial writeup.
http://fullsizebronco.com/forum/showthread.php?t=25824
Adrianspeeder
Old Nov 4, 2005 | 09:13 PM
Unlawful's Avatar
Registered User
looks like a plan, would like to have a little more info on the wiring harness tho, should be able to rig up something in the salvage tommorrow, I got 60 miles from home today and the damn truck wouldn't start, but luckily I got a boost from a really hot chick and made it to Canadian Tire \ and got a 1080 Cranking amp battery, but when I come to a stop light the amp gauge still drops, the alt is only a year old, I only run two cheap 55watt aftermarket lights on the push bar so it shouldn't draw that much more juice.
Old Nov 4, 2005 | 09:31 PM
What amp gauge?
Only added two lights? Your 95amp alt should be fine then.
Adrianspeeder
