92 F150 mass air conversion kit info
Old Oct 13, 2005 | 09:10 PM
92f150302's Avatar
anyone done this, im looking to get a good price on one, not 700 bucks.
Old Oct 20, 2005 | 09:56 PM
92f150302's Avatar
nobody's put on a mass air flow kit?
Old Oct 21, 2005 | 06:46 AM
StrangeRanger's Avatar
Why bother?
On a near stock engine, you lose performance with MAF.
On a moderately built engine MAF has no particular advantage over S/D.
If you're going to supercharge it, you need MAF, otherwise forget it.
Old Oct 21, 2005 | 08:34 AM
adrianspeeder's Avatar
Someone did it over on fullsizebronco, but they had cam mods i think. I'll do a search...
Adrianspeeder
Old Oct 21, 2005 | 08:23 PM
92f150302's Avatar
Originally Posted by StrangeRanger
Why bother?
because i have a highly built engine and drivetrain, and im looking for more off the line, and a stronger ride
Old Oct 21, 2005 | 08:46 PM
Unless you've added a blower, you can probably handle your needs with a re-flash of your existing PCM
Old Oct 22, 2005 | 10:17 AM
92f150302's Avatar
no, doesnt work like that
Old Oct 28, 2005 | 12:02 AM
dvldog458's Avatar
I did it and it was well worth the loot. Before I converted to mass-air I had heads installed,cam, larger T/B, 24# injectors and it ran like azz.(Even w/ a chip)
The mass air cleaned it right up and it idles nice and smooth now. I did have to upgrade the MAF to 75 mm. The stock one that comes w/ the kit was small and would have choked my setup. Besides I needed it matched to my 24# injectors.
Keep your eye on Ebay. Every now and then I will see a kit go for cheap.
