engine miss
Old Sep 26, 2005 | 03:34 PM
topgun3208's Avatar
engine miss
have a 90 f150, 5.0l, I started noticing the tach jumping up and down, now there is a miss in the engine. Replaced plugs, wires, pcv valve and filters for emissions test. Any idea what the potential prob is here?
Old Oct 1, 2005 | 04:27 AM
NIUPonyBoy's Avatar
Same issue here. Had it licked I thought at one point but nope. It is back and worse than ever! Good luck. John
Old Oct 1, 2005 | 10:49 AM
topgun3208's Avatar
it's saturday, nice and cool, a good day to do a little wrenching on the engine. never had the problem until I put the wires and stuff on. going to go back and check all the connections and whatnot. we will see from there
Old Oct 1, 2005 | 11:39 AM
topgun3208's Avatar
first thing I did was pull the distributor cap and it is nasty. most of the little metal tabs the rotor makes contact with are pitted and uneven in size. once the wife gets back with her van i will go and pick up a new one and see if that is the problem, hey it's a start.
Old Oct 1, 2005 | 01:25 PM
adrianspeeder's Avatar
Should always do plugs, wires, cap, and rotar together.
Adrianspeeder
Old Oct 1, 2005 | 02:39 PM
topgun3208's Avatar
Adrianspeeder
you are exactly right speeder and I generally do, but wanted a cheap and fast fix for emissions (readings were lower than the past 2 tests). anyway, replaced the dist. cap and rotor, the miss is still noticeable during idling and 1st thru 3rd gears, went into 4th on highway and into 5th and ol betsy purred like my cat. at least half the problem is gone. time to break out the shop manual and start troubleshooting, ah life is a beach
Old Oct 1, 2005 | 03:33 PM
Cool,
Now pull the codes and see if you have any. Bet there are one or two in there.
Adrianspeeder
Old Oct 1, 2005 | 04:05 PM
topgun3208's Avatar
thats an idea, havent had a "cel" come on. I have a good sunpro reader, the kind autozone uses when u go to them for cel codes. maybe tomorrow i will check it if the wife doesnt pull out her "honeydo" list thanks for the info
Old Oct 1, 2005 | 04:08 PM
topgun3208's Avatar
location
by the way speeder, I notice u r just up the road from me, we pass thru Harrisburg on our way to Canada
Old Oct 1, 2005 | 07:53 PM
You could still have codes without the CE light on. My 92 was running like poop last year with a bad EGR system and no light at all.
Adrianspeeder
Old Oct 9, 2005 | 11:20 AM
PKRWUD's Avatar
Make sure that the plug wires going to #7 & #8 are not touching each other anywhere. They need to be separated from each other all the way from the distributor cap to the spark plugs.
BTW, for future reference, the best way to improve your emission test results is to change your oil and filter, and get the driveline as hot as you can without overheating just prior to the test. In fact, on your way to the test center, take the long way, and never shift it beyond 3rd gear. You want that baby as hot as you can get it.
Old Oct 11, 2005 | 03:52 PM
topgun3208's Avatar
had a code 77 come up this weekend, doing some checking into it now
Old Oct 28, 2005 | 04:01 PM
PKRWUD's Avatar
Code 77 just means you didn't do the KOER self test properly.
Old Oct 29, 2005 | 12:19 PM
topgun3208's Avatar
yeah, I tossed that question around to a few guys at work, and they pretty much mentioned the same thing, it did say operator error, something bout cylinder too. I have gotten it down to a minor thing now with new plugs. thanks so much for the reply
Old Oct 29, 2005 | 12:21 PM
topgun3208's Avatar
darn, I quoted myself, duh lol :o
