Can an '86 top go on a '94 Bronco?
Old 04-25-2005, 06:14 PM
jdpollen's Avatar
This last winter, I acquired my dad's '94 Bronco. He rolled it into a pretty deep snowbank, so the damage is minimal, but the fiberglass top did crack pretty bad. I found another top on an '86 Bronco that's in pretty good condition. Does anyone know if I could use the '86 top on the '94? Gracias...
Old 04-25-2005, 08:36 PM
snappylips's Avatar
I'm pretty certain that the tops from 1980 through 1996 are interchangable, except for the rear seat belt mechanisms.
One way to find out.
SL
Old 04-26-2005, 12:12 PM
jdpollen's Avatar
Thanks SL! I'll check on the seatbelt anchoring points and see if I can retrofit the anchoring points to the top. I'll also have to do without the third brake light, but no biggy.
Old 04-30-2005, 11:04 AM
adrianspeeder's Avatar
Yes they will bolt on but, you wont have the seat belt mounting point, interior cargo light, or third brake light. Depending on your inspecition, the lack of a brake light could be a problem.
Adrianspeeder
Quick Reply: Can an '86 top go on a '94 Bronco?
