Problems
Old Dec 16, 2003 | 08:39 PM
LLoverCrazyJay's Avatar
Problems
Since it has been cold, i've been experiencing problems with my clutch, not wanting to go in gear and such, tonight right when i got in my drive, (changing gears) i depressed the clutch took it outta gear and pumped the clutch as i've been having to do, and it just goes to the floor. So, i figure it must be clutch or slave cylinder. I figure i might as well replace those, and the throw out bearing, so what do you think it is? Off to O reilly.com to check prices.
Old Dec 16, 2003 | 09:13 PM
dave186's Avatar
did you check the fluid level? your slave cylinder could be leaking.
Old Dec 16, 2003 | 10:05 PM
If it were low(not saying it is) what fluid do i put in it.
Old Dec 17, 2003 | 09:03 AM
Update:
Fluid level was full. Am driving a 95 Dodge caravan for the time being. I shall have plenty of time to fix it in the future, sunday this weekend until wednesday of next week. Christmas break. Anyways, i'm gonna go ahead and purchase a new clutch and pressure plate, slave cylinder, and throwout bearing. Laters
Old Dec 18, 2003 | 09:04 PM
With some thought help from some people i know, i'm going to first try bleeding the clutch, if that doesn't help i'm going to purchase a slave cylinder.
Old Dec 18, 2003 | 09:15 PM
dave186's Avatar
its brake fluid. give bleeding it a try, ya never know. I would also try taking the hose off of the slave and see if any fluid comes out when you pump it.
well that might now work cause thats like a quick connect couple and it doesnt leak when its undone. cause its kinda weird that you fluid is full and it doesnt work, i would think that if it were the slave cylinder it would be leaking fluid.
maybe somebody else has an idea?
Old Dec 18, 2003 | 10:17 PM
I do not know, myself, but i do thank you for your help!
