Dont you just hate it.
Old Nov 19, 2003 | 11:06 PM
bigreds2005's Avatar
Red face Dont you just hate it.
Well, I finally got to use something I learned in drivers ed...
Like how to stop with NO brakes, ha ha ha that was fun, NOT! it was nuts I left football practice, dropped my friend off and on my way home I went to slow down and the brake pedal went the floor!! I was like Oh S*IT.. so I dropped it from drive to 2 truck slowed down and then shifted into 1st... I pulled in to the parking lot of the school and caught my breath and thanked god I didn't hit anything (ive only had my license for a week) and checked things out, looked around no fluid leaks around tires. so I called my dad told him what happened, he just laughed. he told me to check the fluid, I did nothing in it. I called one of my friends told him to stop at the store and bring me some brake fluid. Brakes tightened up a little bit to make it home. now I just got to figure out whats wrong with my truck!
Nick
1993 F-150
Old Nov 20, 2003 | 12:41 AM
beastie's Avatar
sounds like air in the lines.
Old Nov 20, 2003 | 12:51 AM
when i first checked it there was none in it... i kept pumping the brake and it tightend up but then it just went to the floor again...
now i have no truck for a week noooooooooooo
i guess i'll just eat some
Old Nov 20, 2003 | 12:54 AM
beastie's Avatar
Maybe the break booster thingy went out...I have no idea but Im just giving you ideas
Old Nov 20, 2003 | 05:29 AM
1depd's Avatar
Probably a leak somewere. When you pumped the brakes it probably increased the air pressure then it leaked out and no brakes.
Old Nov 20, 2003 | 08:04 PM
FORD302GUY's Avatar
You HAVE got a leak. Brake fluid dosent just magically vanish. Pull your truck onto a clean surface and start pumping the crap out of the brakes. You should eventually see fluid start leaking onto the ground. Trace the leak, fix it, and then bleed the system and you should have brakes again.
Old Nov 20, 2003 | 08:40 PM
Yankee7985's Avatar
You do have a leak, and it could be a number of things.
1. Master cylinder: Check for leakage at power brake booster, if equipped.
2. Inside, under the dash where the brake pedal rod goes through the fire wall.
3. Front calipers: check for leakage at piston or with the associated lines.
4. Real caliper/wheel cylinders and associated lines.
5. ABS controller, if equipped
Don't drive it with this problem
Old Nov 20, 2003 | 11:18 PM
Oh I wont.
Old Nov 21, 2003 | 11:43 PM
Ok I found the leak, when i hit the brakes, it looks like it leaks from the frame, i assume that must be a main brake line, right? is that easy to fix? if not how much do you think it will cost at a brake shop?
Old Nov 23, 2003 | 11:32 AM
Yankee7985's Avatar
bigred,
I would try to pinpoint the leak. You state that it is leaking by the frame. For all you know, it may be leaking from a hose fitting and running to the lowest spot, which may be at the frame. I suggest that you get some help in finding the exact spot of the leak.
Old Nov 23, 2003 | 02:36 PM
Ford4ever's Avatar
There is only one line that runs from front to rear i believe, so you will need to replace the whole line. and if your master cylinder ran completely dry of fluid you will eed to bleed that first before you bleed the rest of the system.
It will probably only cost you $150 for a shop to do it.
-Jon
Old Nov 23, 2003 | 10:52 PM
now that football is over (lost in the semis) i can find time and take my truck in to get it looked at and maybe fixed whoo. I hate driving my parents trucks, there not fords ones a GMC and a jeep with a 4 banger.. miss MY V-8. anyways thanks for the help. I'll let you know when it gets fixed.
Happy thanksgiving everyone!
Old Nov 24, 2003 | 10:13 PM
fordman35's Avatar
have some one pump the brakes for you whail you lay under it and look for the leak my guess is its at the back where it tees to the right and left before the axel
Old Nov 25, 2003 | 07:09 PM
well i'm taken my truck to the shop tomarrow, so I will have it back after thanksgiving.
Old Dec 1, 2003 | 07:11 PM
finally got my truck back today. yeah. only problem is I had them put on smaller tires(for winter) and now my truck is all over the road and there is more play in the stering wheel. got to do some homework,
