EVP Sensor vs. EGR Travel
Old May 5, 2003 | 11:17 AM
billman's Avatar
For the '95 in the sig:
I have been trying to solve a slightly shaky idle, rich exhaust, and poor gas mileage for a while now.
While diagnosing the EGR system, I came across a possible issue with the EVP sensor.
The EGR valve holds a vacuum without leaks. According to the Haynes manual, the sensor should read slightly less than 5kohms across VREF and EVP (mine does). Next, while applying vacuum, my sensor read no lower than 850 ohms (hit that at 10 in Hg and stayed there all the way to 20 in).
I then removed the sensor and manually checked the travel of the piston. Fully extended was around 5k and fully compressed it hit about 250 ohms (much closer to 100).
Also, it reads around 500 ohms across EVP and SIG RTN, where the manual states it should be slightly more than 100, but no lower.
Does anyone think I have a problem with the sensor?
Old May 8, 2003 | 09:47 PM
Macgyver's Avatar
whats the computer say?
Old May 9, 2003 | 12:26 PM
billman's Avatar
Thanks for replying.
No codes, if that is what you are referring to. I understand that this may be a goose chase, but the symptoms that I am describing happened very suddenly.
