Saleen S331 Radiator Aluminum Dual Bypass Upgrade
I had purchased about 150 of these radiators a few years back when Saleen closed the local plant and discontiued the s331. I sold most of them a while back but I saved 5 for personal use. I put one in my truck and have 4 left. I will copy the information I had on them below. I am looking for $165 plug shipping each. Let me know if you have any questions.
Double Pass Aluminum Cross Flow Radiator which is supposed to be a direct fit for 2005 thru 2008 F-Series Ford Pick-ups with push in tube type transmission cooler fittings. It is supposed to fit all F Series pick ups’ from 1997 on which use pin type mounts. This type of radiator has double the cooling capacity as a conventional radiator. The inlet and outlet are both on the passenger side and you will have to adapt your hoses on 2005 to 2008 models and Trans cooler lines and hoses on earlier models 1997 to 2005.
This Radiator is an original New Ford Saleen S331 with Supercharger and costs over $800.00 at Saleen Dealers. It is beautifully detailed and the Aluminum looks like Chrome.
Goodyear 62039 Is the Lower Radiator Hose you will need
· Weight:
25 POUNDS
· Radiator Dimensions:
37 13/16” Wide
17 5/16” High
19 5/8” High Top of Pin to Top of Pin
· Core Dimensions:
31 7/8” Wide
17 5/16” High
2” Thick
· Pin Dimensions:
Top Pins 35” Center to Center Wide
Bottom Pins 36 ¾” Center to Center Wide
Pin Diameter 5/8” (0.61)
· Outlets:
Top 1 ¾”
Bottom 1 ½”
· Cooler Lines (push in):
12” Spacing between
· One row with 2” wide cooling tubes
· Weight:
25 POUNDS
37 13/16” Wide
17 5/16” High
· Core Dimensions:
31 7/8” Wide
17 5/16” High
2” Thick
· Pin Dimensions:
· Outlets:
Top 1 ¾”
Bottom 1 ½”
12” Spacing between
Click This link for pics
Saleen Radiator Thread
It will fit in the body of a 4.6 I just don't know what you will have to do with the radiator hoses. I would maybe look up the upper and lower radiator hoses on a 5.4 and compare them to the 4.6 if they are the same it should be easy if not it could be a project.
Shipping is $52.79 and from what i have read it works with the stock fan.
