saleen radiator
That is the flex-a-lite FAL 270 kit. Now they are over $500.00
https://www.f150online.com/forums/me...-installed.jpg
Its an inferred reading from the cylinder head temp(CHT)
anyone running flex a lite fan/controls with underdrive pulleys???...Troyer...
just wondering if the reduced pulley size causes problems with the fan control not getting proper power from the alternator/battery???
One word of caution if you go with a Flex A Lite on an 07. You will have to re-locate the ABS Motor back on the frame about an inch for clearance if remember correctly, not a big deal..just drill a couple of new holes
they're around just gotta look for them...
Why Saleen? The radiator hoses are backwards. See if you can find a Ford Racing M8005-P221 that way you can use the stock hoses and connections.
http://dagostinoracing.com/index.php...oduct_id=16117
I got one Hidden away. $175 off eBay. The FAL Monster fits on lovely.
The lower hose is on the wrong side but you can buy a hose ($12 eBay)
Dual pass so more efficient than the regular and FRP gravity RAD.
I will pop some pics up when I eventually get it fitted.
