high centered in a swamp
get a few guys with shovels and start digging lol. then after you do that for a little the backhoe would be your best bet as long as its 4wd. even if he got that stuck he could work it out with the bucket
You can create your own bomb proof anchor by using simple items. I'd get 4 stakes, 3 short sections of rope, and 1 come-a-long. Place the stakes in the ground in line with your truck heading away, with about 2 feet between stakes. Each stake should be about 2/3's in the gound and tilting away from your truck at about 45 degrees. Tie the top of each to the bottom of the next one in line. The come-a-long is attached to the first stake in line, and start pulling. If you find that the stakes come out of the ground or move in anyway, add another one. We use this system for rescue all the time in the Fire Department when we cannot get another truck, or tree, or other bomb proof anchor.
Thanks,
