BL and Towing Abilities?
Old Aug 15, 2009 | 10:09 AM
mhockey9090's Avatar
I got a body lift and i did drop the hitch as well so the hitch is in where the factory bolts and such are. I figure i would have the factory towing capabilities? Guess my question is that i will be doing alot of off roading when i return from my deployment so just wondering if it will be good too use bc im also looking at this to get to connect a strap too:
http://www.offroadunlimited.com/orus...dproduct=16829
http://www.offroadunlimited.com/orus...dproduct=16797
Old Aug 15, 2009 | 09:44 PM
powerstroke73's Avatar
Ouch, as if my headache wasn't bad enough before reading that trainwreck of a post. I'm still trying to figure out what you actually said you did to your hitch. You do realize that when you do a body lift (or any lift for that matter) you DO NOT touch your reciever hitch, or at least you're not supposed to. As long as it hasn't moved then how could moving the body possibly affect the tow rating?
