Winch
Old Sep 20, 2008 | 09:51 PM
Ford4x4er's Avatar
Winch
Ok so i have a 97 f150 2wd and i would like to put a winch on it. I have been researching but can find a pleasable mthod of putting it on the front of my truck. Can someone please help me and tell me a good setup. i was thinking bout a vortex whinch, my budget is around 800 but ill be willing to spend more, thank you
Old Sep 20, 2008 | 10:31 PM
4.2trimble's Avatar
your budget is alittle steep but you can pull it off.
you need something to mount it on. WARN sells a hidden winch mount.
Id also recommend going with nothing smaller than 9k (im getting the 16.5)
Old Sep 20, 2008 | 11:02 PM
Ford4x4er's Avatar
ok thanks but does this moutn on a 2wd without tow hooks? ill go look
Old Sep 20, 2008 | 11:07 PM
NoLongerJeepin's Avatar
With or without tow hooks wont matter. The frame is the same. The holes the tow hooks mount to are used to mount the winch. You'll be fine.
Old Sep 20, 2008 | 11:08 PM
4.2trimble's Avatar
yeah i dont think it matters 2wd-4wd. its a tray that mounts inbetween the frame and the winch sits in it.
check out the WARN TALOR series
Old Sep 20, 2008 | 11:15 PM
Ford4x4er's Avatar
im looking and i cant find any for 2wd
rcfreak24's Avatar
http://images.google.com/imgres?imgu...%3D1%26hl%3Den
Old Sep 21, 2008 | 12:52 AM
Ford4x4er's Avatar
o well im gunna go to the shopp tomorrow and talk thanks for ur help
Old Sep 21, 2008 | 11:15 AM
4.2trimble's Avatar
That is exactly what im thinking about
Old Sep 21, 2008 | 11:32 AM
06yz250f's Avatar
trimble,
is your winch still gonna be hidden even tho you have a BL?
Old Sep 21, 2008 | 02:53 PM
4.2trimble's Avatar
Originally Posted by 06yz250f
trimble,
Mines gonna be hidden but not like the pictures above in the link. (with a body lift it would be half hidden.
Im going with a total custom front bumper with a winch mount in side it.
Old Sep 21, 2008 | 03:28 PM
Whapt's Avatar
What about getting a front hitch and getting the cradle that uses the hitch so you can use it front or rear like this... http://www.realtruck.com/hidden_hitc...1008P1C1T.html
Old Sep 21, 2008 | 05:00 PM
Ford4x4er's Avatar
thats what i was thinking but im not sure how it would look, thats probably wat i will do thought
Old Sep 21, 2008 | 05:15 PM
Ford4x4er's Avatar
i cant find one for 2wd thought there all 4wd only
Old Sep 21, 2008 | 11:07 PM
Talk about overkill
Its going to take alot more then that little hide a winch to mount that thing. Your going to need a full custom front bumper not to mention beefing up the from suspension.
Why not just go for the 9500? It's perfect for your truck. A good winch should be about 1.5xGVW
