E rated tires on the dunes?
Old May 8, 2007 | 12:07 AM
Koosh's Avatar
I'm having a problem finding the size tires I want (33s) without going too wide and with a normal load rating. I've pretty much decided on either BFG AT/KOs in 305/65/18 or GY Wrangler SA 275/70/18. They're within a half inch of each other in height and theyre both E rated.
My question is, how will E rated tires do on the sand dunes with really low psi? Will they flatten out enough to get adequate traction?
I'm not a die hard duner by any means, but we do go once or twice a year and I would like to avoid the embarrassment of not being able to make it up the big hills in my new truck!! lol
Thanks in advance!!
Old May 8, 2007 | 09:48 AM
Bryndon's Avatar
Wider is better in the dunes, go for the 325. at the same air pressure, there will be minimal difference in flex with a lower load rage - they acheive higher load ratings at higher pressures - and the tire is designed for higher pressure.
