Never Use Chains!
Old Mar 23, 2007 | 08:08 PM
  #46
Bryndon's Avatar
Originally Posted by Steve83
You said it! I have some 1/4-20 Gr.8 bolts here. Can I ****** my 3-ton Bronco if I use both of them to attach a 6" strap to another fullsize truck?
I had retyped something and lost the 1/2" grade 8 bolts - but if you want to use 1/4" go for it - I've seen more than a few people do that and worse.
Old Mar 23, 2007 | 08:11 PM
  #47
Bryndon's Avatar
Originally Posted by Josiah
I'd recommend 3/8's. And just remember, your connection is only as strong as your weakest link. If you use a POS strap and it snaps while connected to a chain, your chain will be on it's way as well. Which happened to me while pulling out a buddy's stuck Blazer, he was on his frame. I have this on video and will be putting it in my next video, it's wicked. Broke the back window (vertical power sliding), damaged the hell out of the tailgate and nearly hit the passenger up front.
If the strap broke, the chain would fall to the ground. The chain would have to break and still be attached to the strap to become a weapon - once again the reason why chains are an issue.
I have seen many straps break. The interesting thing is that not one of them did any damage. If the mounting point breaks or the attaching hardware, different story. But straps themselves are inherently very safe.
With either means of recovery, it's the dufus in the truck that generally causes the problem.
Old Mar 24, 2007 | 01:13 PM
  #48
Steve83's Avatar
... Broke the back window (vertical power sliding), damaged the hell out of the tailgate and nearly hit the passenger up front.
A guy I went to high school with was killed a few years ago exactly that way. The guy he was pulling had removed the pin from his draw bar & forgotten that the rust/mud was the only thing holding it in. My friend caught a 100-mph 2x2" square tube in the back of the skull.
Nothing broke, but if they had been using chain instead of rope, it wouldn't have gone anywhere.
Old Mar 24, 2007 | 02:20 PM
  #49
jjbathke2001's Avatar
I have seen the same thing Josiah had happen to him. when using a strap it broke and slung the the whole thing thru the back window. Chains do not always fall to the ground. That said i have pulled my fair shair of people out of a mess and i allways used chains untill i came across the rope i have now.
Old Mar 24, 2007 | 05:15 PM
  #50
Bryndon's Avatar
Steve83, Sorry to hear about the guy you knew. Standard practice, don't attach unless you know what you are attaching to.
Old Mar 24, 2007 | 09:59 PM
  #51
Steve83's Avatar
I've pulled out cement trucks, construction equipment, & even armor, so I know to be careful. He obviously wasn't, and paid the ultimate price.
Old Mar 25, 2007 | 08:37 AM
  #52
Bryndon's Avatar
Steve83, I would wheel with you anytime! You know how to have fun and be safe - there's a lot of guys that have trouble doing both!
Old Mar 25, 2007 | 02:01 PM
  #53
M125X's Avatar
We have a 100lb chain; safe if used properly.
