Towing and 4 wheeling on the beach
Originally Posted by Thelt
I have done my share of wheeling in the sand at Hatteras and I have never seen anyone pull a RV out on the beach. I would not have thought you could do that and not get stuck. Maybe the sand is not as soft where you live? I have seen class C motorhomes on the beach south of Hatteras on the core banks but not the sand there is harder with more sea shell mixed in.
-Joe
On Long Island if you don't get there early you won't get a spot and we are talking about beaches with 200 spots on them. 100 on the bay side and 100 on the Ocean side. And there are a few of them. Last year we had little or no rain and the sand was very soft. On top of that to get to the Ocean side you have to climb the dunes. Most of what you see out there are 5th wheel rv's. Mine is 33ft long and weighs in at about 12,000lbs dry and I am by no means the biggest rig out there. But with airing down to at least 15lbs and 4lo we all make it as long as we use our heads and be careful. I have never once seen a blown bead but have spent many hrs helping guys that did not want to air down. Thanks for eveyones input. A lot of good people with good ideas. This was a good tread. May be see you all out there trying all these ideas having fun.
While going through this thread, I see a lot of talk about measuring the footprint after airdown. When you do this measurement, make sure you measure the length of the footprint. This is more important than the width. The airdown is supposed to give you better taction due to the length of the footprint not the width, so don't try to go down far enough to make your sidewalls roll over.
