4.6 making weird noise
Old Dec 9, 1999 | 07:15 PM
ncbassin's Avatar
Question 4.6 making weird noise
My 99 4.6 makes a weird noise on most start ups. It sounds like a bearing (possibly the idler). What has me confused is the rpm will jump 300-500 when this occurs. It is most common at aprox 1200-1300 rpm and it will attempt to climb up to 1500-1600 rpm if I would let it. I normally am going in a straight line or stopped. It can occur also after the engine has been run the normal 30 miles to work. Any ideas?
Old Dec 10, 1999 | 02:08 AM
cm's Avatar
cm
Post
Have you read some of the threads in the engines section? Piston slap was a common problem on a lot of motors built at the windsor plant. I suggest checking out the piston slap summary posted by (I think) ml in the engines forum.
-cm
Old Dec 10, 1999 | 09:00 AM
cphilip's Avatar
Post
I don't think there were many if any 4.6L's made at the Windsor plant in 99. Windsor is the only ones with any reported piston slap in a 4.6L. Check you VIN for the build location. If it is a Windsor 4.6 them maybe.
Old Dec 21, 1999 | 08:58 PM
TampaBayLightning's Avatar
Post
test
Rich
1999.5 SVT Lightning - Red. Super Chip. K&N Filter. Viper Alarm w/remote start, clear corners, tow package, cd changer, cover, MTX Thunderform w/ 2 10" MTX 200w subs. 5-channel 300w Clarion amp., etc. Build #2755
stbtb@Tampabay.rr.com
http://www.zing.com/picture/ff/e7/d9/6/ffe7d96a.jpg
1999.5 Expedition XLT
