Need torque for 9.75" bearing caps
Old Oct 13, 2002 | 04:13 PM
67mike's Avatar
Question Need torque for 9.75" bearing caps
Hey guys.......the chilton mannual doesn't have the torque specs for the rear differential side bearing caps....on a 8.8" it is 80 to 90ft/lbs.....What is it on the 9.75" rear???
Thanks a million!
Old Oct 13, 2002 | 07:09 PM
xcracer's Avatar
the torque spec is 110-120 ft-lbs...:o
Old Oct 13, 2002 | 09:12 PM
67mike's Avatar
WOW!
Mine is only torqued to 75ft/lbs!
No wonder I am hearing a strange clunking from the rear on cornering and bumps!
I hope I didn't screw it up!
Old Oct 14, 2002 | 10:25 AM
67mike's Avatar
Where did you get that number?
I just looked at ring amd pinion.com and there spec chart says 80ft/lbs?!?
Is your number for the 9.75"??? Is it from the factory mannual?
