ORP effect on gear ratios
Old May 23, 2001 | 11:08 AM
webfoot's Avatar
Question ORP effect on gear ratios
Does anyone know what the effect of 17" wheels is on gearing? I have 3.55 axles, wonder how much power loss there is.
Old May 23, 2001 | 02:53 PM
acadianbob's Avatar
Post
if you know the circumference of your 17" inch wheel and can get the same measurement on a 16" wheel, you can compute the percent difference. let's say the 16" wheel is 90% of the 17". . then the 3.55s on your truck would be about the equivalent of 3.20 compared to a truck with 16" wheels (3.55 x .9)
Old May 23, 2001 | 05:03 PM
webfoot's Avatar
Talking
<font face="Verdana, Arial" size="2">Originally posted by acadianbob:
if you know the circumference of your 17" inch wheel and can get the same measurement on a 16" wheel, you can compute the percent difference. let's say the 16" wheel is 90% of the 17". . then the 3.55s on your truck would be about the equivalent of 3.20 compared to a truck with 16" wheels (3.55 x .9)</font>
Thanks, Bob. That's easy!
Old May 23, 2001 | 10:44 PM
MechE's Avatar
Post
I wouldnt think wheels would make any difference on gearing, just what tires are on the wheels. The OD of the tires is all that matters for gearing.
Old May 24, 2001 | 03:57 PM
webfoot's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by MechE:
I wouldnt think wheels would make any difference on gearing, just what tires are on the wheels. The OD of the tires is all that matters for gearing.</font>
That makes sense, but there are many tire profiles and different treads. What tire would represent the standard for comparison
purposes? Or is there a standard - maybe you just have the driveshaft/axle ratio to go by?
