leak in rearend
Old May 23, 2001 | 08:19 PM
ovalnut's Avatar
Angry leak in rearend
I have replaced the rearend seal on my 97 f150 twice. it still is leaking is there something im doing wrong.
Old May 24, 2001 | 01:54 AM
KYFordFreak's Avatar
Post
IMO you might have warped diff cover. Then again I could be wrong.
97 Ford F150 XLT 4x4 4.6L auto, Std cab/Long bed, 3.55LS rear axle, PW,PL, and PM, captian chairs w/arm rests
Sylvania Cool Blue Bulbs, Ford logo hitch and license plate, tinted windows, blackouts front and rear(w/ford logos on front blackouts),ventvisors all around, painted logos on door sills and under hood, 55w backup lights, K&N Filter, custom 4x4 emblems, cup holder/LED mod, 99 F150 Triton V8 emblems, and much more to come
Old May 24, 2001 | 11:55 AM
bambino's Avatar
Lightbulb
Just make sure you use a good bead of RTV Sealant, the black stuff. Then torque all your bolts to the same specifications. I've done it on all my vehicles with out problems.
Warped cover might be a prob, just an excuse to get a new fancy one
Bambino
Bambino Worldwide
Owners Gallery Truck #179
1999 reg cab/short box/ORP/Silver on Dk Graphite - 3.55; 4.6l 5sp; Factory Tonneau; 40 chan CB/Maxrad Antenna; Kicker amp'd sub tubes; Rockford Fosgate components up front; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820s; Amsoil Series 2k in the driveline.
Old May 24, 2001 | 01:24 PM
willards1's Avatar
Thumbs up
I changed my rear diff. oil a couple of months ago. I used a gasket maker called "The Right Stuff". It worked great... very easy and so far not a drop. It was a bit pricey if I remember correctly around $10.00-12.00 a can. I bought it at PepBoys. Hope this helps.......
2000 F150 SuperCab/Long Bed 4X4 ORP; 4.6L Engine; 5 Speed Manual Transmission; Hellwig Anti-Sway Bar; Westin Step Bars; Air Raid FIPK; BedRug; SNUGTop TruckCap; Rancho RS9000 Shocks
Old May 24, 2001 | 01:59 PM
CDeHeer97's Avatar
Post
It sounds like your talking about your pinion seal, is this right or are you indeed talking about the diff. cover. The pinion seal will be a bit trickier. However if you are having trouble with the cover and have the 12 bolt rear I had similar problems and no gasket is available, So I scanned my pan and set a file to laser cut one from sheet gasket, no problem since. If a gasket would help I'll supply you one for the cost of material + shipping.
let me know.
97 F-150 XLT Ext.cab
5.4 auto o/d, 3.55 LS
Elct. 4x4, Tow Pkg.
Capt. Chairs, Console
Two Tone paint,Black on Silver, Rancho RS 5000's
Ford Bed Liner,Soft Tonneau
Bug sheild
Sony xplode CDX-600,MTX 325watt amp, 2 10" JBL subs.
