'01 Rear Thumping under light braking
Old Apr 2, 2001 | 06:55 PM
primerate's Avatar
Post
I also have an 01'SCREW with the thumping. The dealer replaced the rear tires and is going to replace the rear but it does sound like something in the drivetrain and the dealer agrees. It is going in tomorrow. I will post a follow up. Anyone with any advice in the meantime would be appreciated.
Old Apr 3, 2001 | 12:23 AM
Rustyscrew's Avatar
Unhappy '01 Rear Thumping under light braking
I have an '01 Screw with ~16k mileage. It has developed a thumping coming from the rear when slowing down with light pressure on the brakes. I can apply power, while braking, and the thumping stops. Thumping slows as speed drops, sounds as if it is related to wheel rotation. Any ideas? I'd like to have an idea before taking it to the dealer.
2001 F-150 Lariat Screw 4X4, White/White, 5.4L, Tow Package
CLS III, 3.55 LSD, Ford Nerfs, ORP, 6 Disc CD
Leather Captains Chairs, Bed Extender
Mods: Rhino Lining, Snuglid
AR Sliders, GDYR AT/S 305/70/16
Old Apr 3, 2001 | 08:02 PM
Larry K F's Avatar
Exclamation
I have a 2001 F-150 and have a thump once in awhile when braking. I'm taking it in 2 days from now. It has 400 miles on it!
Old Apr 3, 2001 | 09:05 PM
primerate's Avatar
Lightbulb
Well my dealer discovered a "bur" on the pinion gear that was causing the thumping sound while decelerating. They are replacing both the ring and pinion gears. I will update tomorrow whether or not this was effective. I will say that the techs at this dealership have historically been right on with thir diagnosis..
Old Apr 4, 2001 | 09:20 AM
Rustyscrew's Avatar
Post
Thanks Primerate. I'll be calling to schedule service today. I'm always amazed at the amount of info avail. from this board.
Old Apr 4, 2001 | 06:32 PM
primerate's Avatar
Talking
UPDATE: The dealer replaced the ring and pinion gears and viola!! No more noise at all. The gears exhibit no sound at all. This is the way it should be. Good luck Rustyscrew...
Old Apr 9, 2001 | 03:32 PM
Rustyscrew's Avatar
Angry
Took the Screw in today, clunking has gotten worse (or maybe I'm hyper-sensitive about it), service rep has said this noise is normal?? I have real hard time believing this.
Larry K F - any luck with your dealer.
