Replacement hubs
Old Mar 26, 2001 | 10:14 PM
CB's Avatar
CB
Question Replacement hubs
My local service manager says that the auto locking hubs are weak.My 98 has a manual t-case and auto hubs,I want to replace them with manual hubs. Who makes the best and what do you think about this.
Old Mar 26, 2001 | 10:21 PM
Granpa's Avatar
Exclamation
If that 98 is an F-150, then your service manager is weak and needs to be replaced. '97 and up doesn't use the locked/free-wheeling hub idea. Uses a right axle disconnect built into the front diff.
Old Mar 27, 2001 | 02:18 PM
CB's Avatar
CB
Smile
Thanks for the reply.Yea that bothers me about him ,may be he was confused about the year of my truck???
Old Mar 27, 2001 | 07:34 PM
GIJoeCam's Avatar
Post
Maybe he was just confused period! Hubs on a 98.... did you make sure he re-packed the muffler bearings and topped off the blinker fluid too?
But seriously... if you had a pre-97, then, yes, it is a weak design and prone to failure. Warn, MileMarker, and a plethora of other companies make good quality manual hubs for between $150 and $300 a set (both sides). [mutter, mutter, hubs?!..... ] I would like to see him install a set!
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!Clear Corners, Manik Stainless Steel 1-piece brush guard, Custom CB wiring, Uniden PC76-XLW CB radio with K-40 Magna-Mount antenna (for now), 1 set of 165 watt KC Daylighters (for now... more on the way) Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbarw/ 2" stainless steel ball.
List of planned mods: Clear tails, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
93 Probe GT teal, OE rims painted to match, bone stock drivetrain.
