Speedo Calculations
Old Mar 21, 2001 | 08:54 AM
Mav07's Avatar
Post Speedo Calculations
Ok. So I know my speedo is still off with my mods. So here is what I did. I have 33's instead of the stock 31's. And I changed my gears from 3.08 to 4.10. I was told to get a 21 tooth gear to replace my 19 tooth gear. That helped, but did not fix it. So decided to do my own math.
I take the new tire size divided by the old tire size. 33/31 = 1.064516 and
divide the original # of speedo 19 by that # and I get the effective # of teeth. 17.8.
Then I divide the new gear ratio by the old one 4.10/3.08 = 1.331168831 and
multiply that times the effective speedo tooth # 17.8.
By that, the number of new teeth I need to correct the speedo is 23.759 teeth.
I will probably just go with a 23 tooth gear. Can someone check my math and logic and tell me if this makes any sense?!?
1997 Ford F-150
4.2 L V-6
Thrush Turbo Tube catback exhaust
K&N Air Filter
Window Tint
Pioneer 7000R CD player
2 Rockford Fosgate DVC HX2 10's
Rockford Fosgate 500a Amp
Lund bug shield
Vent Shade Vent Visors
GTS headlight blackouts
Bedliner
Chrome Toolbox
3" Body Lift
Lift Lips
305/70R16 ProComp Muds
16x10 Eagle 589
Chrome Westin Nerf Bars
4.10 Precision Gears
Custom Key racing stripes down both sides thanx to some a**hole in the HS Parking lot.
My WebPage
Old Mar 21, 2001 | 10:30 PM
Ian N's Avatar
Post
I agree:
19 *(31/33)*(4.1/3.08) = 23.76
You might want to go to a 24 tooth (if it is available - someone told me 23 was the largest) because it will still be off by +0.76/23 = + 3.3% as opposed to
-0.24/24 = -1%.
Good Luck
Ian
99 Expedition EB
5.4l, 4x4, 4.10'S
WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip
