Spillage seal
Old Sep 23, 1999 | 10:53 PM
ford-tough1's Avatar
Post Spillage seal
A couple of weeks ago I had the slip yoke replaced on my truck. On the reciept it said that they removed the spillage seal. I know it is on the transfer case but what was its purpose and why did they remove it?
1997 4x4 5.4 ORP XLT extended cab Dark Toreador red Westin nerf bars tint HARDER THAN A ROCK AND FASTER THAN A HEART BEAT
Old Oct 8, 1999 | 10:03 AM
Post
Does anyone know what the spillage seal is for.
Old Oct 25, 1999 | 10:34 PM
Post
Anyone, anyone?
Old Oct 27, 1999 | 10:42 AM
JMC's Avatar
JMC
25 Year Member
Post
ford-tough1,
Is there a part number for this seal? My manual (Helm BTW) shows no "Spillage" Seal in the diagram. Is there possibly another name for it?
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
SmittyBilt Nerfs, Borla Cat Back
Modified Air Cleaner Outlet Tube
To Be installed;
Superchips
Old Oct 27, 1999 | 07:18 PM
Post
No part #. The reciept only says: "Replaced slip yoke and removed spillage seal from transfer case". Thanks for your help.
[This message has been edited by ford-tough1 (edited 10-27-1999).]
Old Oct 29, 1999 | 08:21 PM
SPORT2000's Avatar
Post
Why not just ask the mechanic who worked on your truck?????
Old Oct 30, 1999 | 09:41 PM
Superdave's Avatar
Talking
Do you have a slip yoke on the front of your rear driveshaft going to the transfercase?
Old Nov 1, 1999 | 10:42 AM
Post
yes, superdave
Old Nov 2, 1999 | 01:06 AM
Superdave's Avatar
Talking
ford tough 1, When you have a male slip spline coming from the rear of the trans-case and then have a female slip yoke on the driveshaft there is a small seal or plug in the center & back of the slip yoke. Its hidden by the u-joint, it keeps the trans-case oil from seaping out through the center of the slip yoke. I'm not real familiar with the new Fords, but GM used to use this set-up with the same type of spline system mentioned above. You might be able to see if your truck has this by using a good flashlight and looking on the back of the slip yoke , it will be small 1/4" to 3/8" approx. Its not very big but plays an important role, it will give the appearance the rear seal on the transfercase is leaking but its actually coming from the rear of the slip yoke, behind the u-joint. This could be your spillage seal, Maybe? Good luck;0 .
