Power steering making noise
Old Nov 22, 2001 | 08:56 PM
RANCH4x4's Avatar
Ok, I think everyone knows how the power steering sounds, mine does not make a whole lot of noise, but when I turn the wheel to the right it makes that aggravating sound. What can cause this and whats a good way to keep it quiet?
Old Nov 23, 2001 | 10:23 AM
Ford4ever's Avatar
Ford power steering pumps have always been noisy. I don't know how you would quiet it down. Maybe Amsoil or some other company has some kind of additive?
Old Nov 23, 2001 | 10:30 AM
frog's Avatar
In all of my years of owning Fords, I have changed out more power steering pumps than anything else. Couple of tips:
1. Changing the fluid sometimes helps.
2. If you replace it, do not use a rebuilt. I've installed several that made the same noise.
3. The last option is to drive it untill it stops working. That could take years.
Good Luck.
Old Nov 23, 2001 | 11:18 AM
RANCH4x4's Avatar
Thanks guys.
Old Nov 23, 2001 | 03:45 PM
Dennis's Avatar
I'm thinking that if it makes the aggavating sound only when you turn right, it might be caused by something other than the pump. The sound is probably coming from the pump, the normal sound is being aggravated and I think this aggravation might be from extra strain being caused by some binding somewhere in the the steering linkages.
Normally, the pump should sound the same no matter which direction you turn the wheel. If it makes a noise turning left, it makes the same noise turning right.
Old Nov 23, 2001 | 05:22 PM
svtoby150's Avatar
You can here my PS pump all the time. It's very annoying sometimes.
Old Nov 23, 2001 | 10:52 PM
RANCH4x4's Avatar
I was playing with it some more today, and when I put the truck in park and turn the wheel from side to side, it doesn't make "too" much noise outside, for some reason I can hear it more when I'm inside the truck than outside.
Old Nov 24, 2001 | 12:33 AM
bambino's Avatar
Mobil 1 ATF hushed mine up nice and quiet!
Bambino
Old Nov 24, 2001 | 06:31 PM
Dvds's Avatar
Its worse on the passenger side, at least on my 99 Exp. Noticed this while my wife was driving on a trip last summer.
Old Nov 27, 2001 | 08:56 AM
Tiger's Avatar
The OM says to use Mercon. I'm just wondering if anyone has tried Mercon V. This may help.
