1999 expedition 4x4
Old 07-14-2018, 04:03 PM
chris331's Avatar
1999 expedition 4x4
I have a 99 expedition that will not engage into 4x4 when i turn the selector switch with no dashboard lights
Old 07-14-2018, 05:54 PM
Check your fuses.
Old 07-14-2018, 07:04 PM
chris331's Avatar
Check your fuses.
I don't think that's the problem because when I turn the switch I hear a clicking like a switch attempting to switch but it can't so it's cicking over and over plus when I start the truck the low range light will illuminate during the initial light check when the key is turned on. To explain further I was having trouble with my air conditioning defaulting to defrost, the vacuum line from the one-way check valve to the firewall was fine with no brakes so I made an assumption that the vacuum problem was somewhere in the dash so instead of tearing the dash apart I bypassed that line entirely with another line finding the easiest way to route up to the controller which fixed the a/c problem. My question would there be a correlation between doing that bypass and my current four wheel drive problem. I'm sorry about my cryptic descriptions I'm not a mechanic I'm just guy trying to save money
Old 07-14-2018, 08:15 PM
Roadie's Avatar
I'm assuming an expedition and F150 are the same?
Old 07-14-2018, 11:35 PM
glc is offline
There may very well be. Check the hard vacuum lines behind the battery, along with the accumulator in the fenderwell.
Quick Reply: 1999 expedition 4x4
