4X4 Help
Old Aug 12, 2016 | 11:49 PM
Pepejr678's Avatar
4X4 Help
Hey guys i have an 05 F-150 Lariat. I just started having problems with the 4X4 Low. High engages easily but when i try low sometimes it engages and sometimes it doesnt. Could this be a bad connection somewhere or could it be a bad transfer case motor.
Old Aug 13, 2016 | 10:02 AM
Are you engaging it with the truck stopped in Neutral with your foot on the brake?
Old Aug 13, 2016 | 10:08 AM
Pepejr678's Avatar
Yeah. Brake pedal is all the way down. I make sure it's in neutral. I wait about 30 seconds to see it it engages and it doesn't. But other times it engages instantly.
Old Aug 13, 2016 | 11:21 PM
1972-2003f150's Avatar
I would isolate which wire powers the ESOF motor to shift to 4L and see if it's a bad connection or receiving power when engaged. It's in an exposed location so it's not too hard to imagine salt or moisture could've taken it's toll on it
Old Aug 17, 2016 | 08:38 PM
Pepejr678's Avatar
Do you know if theres a sensor on the shift ****. Sometimes i put it in reverse but its actually in neutral.
Old Aug 17, 2016 | 11:31 PM
You probably have loose bolts inside the steering column. Drop the lower cover and look for two Torx bolts. If it doesn't think it's in neutral, 4L won't engage.
Old Aug 17, 2016 | 11:56 PM
Pepejr678's Avatar
It's an 05 lariat the shifter is in the middle console. Does it also have those 2 screws?
Old Aug 18, 2016 | 10:34 AM
Not that I know of - but something is loose or the MLPS is out of adjustment.
Old Aug 18, 2016 | 11:27 AM
Pepejr678's Avatar
I went out this morning and checked 4lo and it engaged and disengaged normally. Then I put it back to 2wd and put it into drive and reverse then I tried putting it into 4lo and it didn't engage. I'll check out that sensor and see what happens.
Old Apr 1, 2017 | 06:56 PM
Pepejr678's Avatar
Fixed
Well guys its been a while but it finally got fixed. My brake pedal switch went out and when i replaced it the 4X4 worked fine
Old Apr 1, 2017 | 07:10 PM
Roadie's Avatar
Thanks for letting us know!
