Oil pressure guage question
I have noticed the past two winters that my oil pressure gauge drops to zero inthe cold when I first start up. After about five to ten minutes the gauge stays steady within normal range. Could this be related to my sending unit or something else?
Some background:
2001 F150 XLT with 192,700 miles, no fluid leaks at all, no rust, Tranny is topnotch, and engine still operating solidly.
So, if someone can assist me i appreciate it.
Mike
Some background:
Mike
+1 on the sending unit. Keep in mind, the gauge either reads ZERO, or about half-scale, it does not show fluctuations in oil pressure that a true oil pressure gauge does. The sending unit is a "normally open" switch, that closes with about 7PSI of oil pressure. When it closes, the gauge goes to about half-scale.
The sending unit "switch" is mechanical, with electrical contacts. They can stick open, or intermittently open when cold.
