Rear end gear?
Rear end gear?
I have a 2001 screw 4x4 with the 5.4 and auto transmission. I don't know what transmission or gears I have but would like to how do I find out? Also do I have ls in the rear end? All I know is it pulls like crazy offroad and when I power brake it or get on it both tires spin. Please help me identify this stuff because I'm going with 295 70 17 tires and I hope I won't have to change gears. I have a 285 70 17 now with no issues
There is a tag on the drivers door that gives the axle code. That code tells what it came with from the factory. There is usually a tag attached to the rear pumpkin that has the gears on it. However, it's possible the gears have been changed if you are not the original owner. There is not enough difference in those two tire sizes to make a big difference.
rear end
hello I have a 1969 ford f250 and my rear end went out on me, and find a rear end from that time is slime to none. I was wondering if I have to get a whole new one, mostly because I don't want to rebuild the old one. or can I use one from the 80's idk if the parts will match up and I'm kinda stuck and trying to get this truck restored with this please help!!!
specs 351 c6 trany and 6 lug rim pattern
