Gear Swap Help
Old Oct 4, 2012 | 01:26 AM
Lifted5.4Lariat's Avatar
Power hungry performance. I'm selling everything you'd need minus getting the actual custom tunes. Here's a link Tuner
Old Oct 4, 2012 | 01:43 AM
The ONLY way you are going to get your gas mileage back is remove the lift and big tires. Period. Besides, the 2 grand you are going to spend for gears and tunes will buy a LOT of gas, and I doubt that you will get much, if any, mileage back.
Old Oct 4, 2012 | 10:24 AM
str8t six's Avatar
go with 4.56 gears.
Old Oct 4, 2012 | 10:55 AM
Even if he does decide to take the tires off a tuner is still a good idea to increase the drivability of the pickup, IMO..
Old Oct 4, 2012 | 11:25 AM
str8t six's Avatar
i agree, being able to adjust the shift points and get a little more power out of these trucks is definitely worth it!
Old Oct 5, 2012 | 10:23 AM
hartzog87's Avatar
I think I'm going to get the edge revolution programmer. and gears later.
Old Oct 5, 2012 | 02:36 PM
That's what I have. It's the cs model so it has more features and color screen. It also programs a lot faster...
Old Oct 5, 2012 | 04:39 PM
hartzog87's Avatar
I think that and a cold air intake is all I am gonna do for now.
Old Oct 5, 2012 | 05:23 PM
^^ doesn't do anything without a custom tune on a programmer......
Old Oct 5, 2012 | 06:19 PM
mSaLL150's Avatar
Truth. Just took off my 35" Toyos and put the stockers back on. Even with 4.56 gears and Troyer 91 tune, I got 14.5 mpg hwy with the heavy Toyos. Same exact setup with the stock tires, 18.2 mpg.
Old Oct 9, 2012 | 10:47 PM
hartzog87's Avatar
even if I got back to the 14.5 with a cold air intake and a programmer I would be happy.
Old Oct 10, 2012 | 03:37 AM
Intake will not improve the mileage one bit and it's going to make it run lean unless you get custom tunes.
Old Oct 10, 2012 | 11:42 AM
I've already tried explaining it.. He's set on a canned Evo and cai for some reason.
Like he said, you need custom tunes on a programmer like a gryphon cs from power hungry performance to even be safe to have a cold air intake. Good luck.
Old Oct 10, 2012 | 03:42 PM
Or you detune it and run it stock.
Old Oct 10, 2012 | 06:38 PM
True but with minimal, if any, gain of any kind.
