Different "clunk" - when driving, not starting out or turning
Old Dec 9, 2011 | 03:12 PM
remaction's Avatar
Sorry, forgot to post vehicle. 2007 - F150 FX4 4x4, 5.4L, 65,000 miles. I have a clunk that I sometimes get while driving 60 mph. It's almost like the rear end went over a sharp bump in the road, but it's not due to the road and is not associated with a transmission shift (automatic). It feels like something has some play and then engages, or something slips then engages hard. I've also noticed that I aslo feel a slight vibration while driving lately. It's not occuring when I start from a stop, or when I start and turn. Just when I'm going along at highway speed, but usually happens when I'm going up a slight grade. Any ideas?
Old Dec 9, 2011 | 04:10 PM
Kinda hard to help you when you don't provide any details on what your vehicle is..........
Old Dec 9, 2011 | 04:12 PM
im gonna take a shot in the dark here and say its a failed Ujoint
Old Dec 9, 2011 | 04:40 PM
remaction's Avatar
Would I not get the typical "squeaking" or "chirping" when starting out if it was a U-Joint? Or is that old school symptoms. I have not had any of that occur.
Old Dec 10, 2011 | 10:43 AM
ParnAZ's Avatar
Might even be a low grade misfire or an intermittent coil failure. Try and re-create it as much as possible and see if a CEL pops up. Patman is probably on the right track though with the u-joints
Old Dec 12, 2011 | 08:33 PM
remaction's Avatar
The U-joints are tight. No movement whatsoever when I try to turn the shaft. I never thought about the misfire possibility. I don't have a service engine light on, but I'll plug in a code reader and take a look.
Old Dec 13, 2011 | 04:39 AM
RiverRatF-150's Avatar
my truck has started to do the same thing. up a slight grade at 60mph or accelerating slightly from 60-65. I was thinking tranny bc my truck will down shift if i apply just a hair more gas. torq converter? tried for about 15-20 mins to get it to trow a CEL but i got nothing. and it did it about 3 times in one acceleration. my truck has about 71500 miles
Old Dec 13, 2011 | 08:55 PM
remaction's Avatar
To RiverRat,
It sounds like the same thing, and happens in the same way you mentioned,but I can't get mine to repeat that often. It might happen only once every couple of weeks. I do not have any error codes showing up. I'll let you know if I figure it out. Please let me know if you do too.
Old Jan 2, 2012 | 03:59 PM
remaction's Avatar
Updated info
I don't know if this is good news or bad, but I had the transmission fluid changed (flushed... however they do it with the machine at the Ford dealer) and it hasn't made the clunk since.......
Old Jan 2, 2012 | 09:29 PM
i was thinking it could be the torque converter making the shudder
Old Jan 3, 2012 | 05:47 PM
chadstoks's Avatar
I feel like I have the same issue with my 04, the low grade misfire from all the posts I've read. How does one diagnose which cylinder its coming from if it won't throw a code?
Old Apr 29, 2012 | 01:01 AM
HamboneFX4's Avatar
Mine will made a clunk sound as well when I am starting from a stop or very slow accell. Seems when the load is at its highest it makes the noise.
05 f150 fx4
