Gear Swap and Mileage
Ok folks need some help. Took my truck in for service, also asked them to take a look at teh rear end, as it has been getting a pretty loud whine/ roar. As I expected the axle bearings are shot. They quoted 1400 to rebuild. Talked to teh folks in Raleigh at East Coast Gear Supply ( great prices and reputation) They will swap both axles to 4.11s and rebulid the rear end for a couple hundred more. Whet I really need to know is wha did everyone that made the switch to 4.11s,mileage do? I am currently running 3.55s, with 33" tires, and averaging around 13.5 mixxed driving. I would be real interested to hear how everyones mileage changed when going from 3.55s to 4.11s. If I am going to lose a ton of mileage it isn't worth it, otherwise it is a no brainer.
Sort of depends on what kind of driving you do most often. It would be a 14%increase in rpms to cruise at the same speed as it would with a ratio 3.55. That said if you do alot of city driving than the engine isnt working as hard to move the vehicle w/ 4.11. 2mpg loss would be a reasonable estimate IMO. It will certainly feel better though with those 33s. You sure its not just the pinion bearings wining? Both axles for 1400 aint too bad.
I usually run pretty close to the speed limit. Of course a lot of that is 70 mph. According to my calculations including squish, Rpms should go up about 11%.
You will be turning some higher revs on the highway, but it is going to be offset by better efficiency and drivability. I'd do it and not look back. I had a similar set up in '92 Bronco.
You're cruise rpm will increase by about 15% at any given speed. So it you're turning 1,900 rpm at 70, you'll be at ~2,200. That's not that significant of an increase in rpm.
