Special tool??
Old Dec 6, 2011 | 09:08 AM
04Supercrew150's Avatar
Special tool??
Does anyone know where I can rent the splined compression tool to compress the clutch packs in a 9.75 carrier assembly?
tried local auto zone, napa and carquest..
I need this tool to remove the spider gears to get the clutches out of the carrier assembly. Right?
could i just use a piece of all-thread and some nuts???
help please!!
Old Dec 6, 2011 | 06:56 PM
ok.. so knowone wants to talk to me? I must smell bad or somthing.
FYI: 3/4" all-thread will not work. Compressed everything about 1/4" then the nuts started stripping and the threaded rod began to twist.
I stoped before I broke the rod. But now I got a bigger problem. Since the nuts started stripping my home made tool is now stuck in the carrrier! #%^&$$!!!
Purhaps if i would have used fine thread all-thread I might have had a chance.
Old Dec 8, 2011 | 10:20 AM
sam1947's Avatar
Don't start multiple posts on a subject, and what to h**L is 'all thread' ?????
Old Dec 8, 2011 | 10:26 AM
It's a piece of rod stock that has been threaded from end to end.....a person can cut it to whatever length they need...hence the term 'all thread'......some call it 'threaded rod'....
