rear end ror
rear end ror
My rear end is roaring and getting worse I have a 2004 f-150 fx4 I'm not sure what gears are in it a buddy told me my pinion gear is loose cuz I can shake my drive shaft up and down with my hand about how much would it be for me to just throw some new gears in it at home
You probly just need new bearings. Pinion bearings, carrier bearings, and both axle bearings while your at it. Did u run the fluid low or get water in your diff fluid from offroading?? bearings dont just go usually due to poor lubrication.
You 'might' be ok..no guarantees..if it was mine and had to replace all the bearings, you can bet I would go the extra mile and do the gears also.
