4.6L 2v: Stroked or blown?
Hey guys,
So, have done tons of google searches, searches on here and other forums, and all over mustang forums too, tryin to decide whether I wanna stroke my 4.6 to a 5.0 or throw a s/c on it. Not to confident in the shops around me to open up my heads so a stroked mod would be worth it, although, I would much rather that than any kind of forced induction if I can help it, not to mention that some of the other people who stroked their motors are claiming over 400hp, if thats true, I wanna know if there's any kind of setup with a s/c that could put up those numbers... But, I have been finding that prices are pretty equivalent too, I know its really all about what I want to do, but I was hoping to get some feedback from people who probably (definitely) know a lot more than me about this, thanks everyone!!!All input is def welcome on this, Im about 6 months out from taking it on
J
J
Hey guys,
J
J
The easiest way to do it with out haveing to change anything on you motor is the stroker kit. its a direct bolt in but labor intensive. the good thing is that our heads are also the same as the mustang GTs and Trickflow makes nice top end kits for them minus the intake so thats anouther option. Stroker kit, with trickflow heads and stage 1 cams for more low end should also bolt on with out any major probs. just remember to re use the stock truck intake.
Now for the the baddest of all options is a full blown motor wich would be a
5.1 stroker bottom end, ported trickflow heads with stage 2 cams, and a Kenne Bell blower to top it off. easy 550+ HP
if you have an 08 like your tag says then im in the same boat seeing i have an 07 looking to do the same thing. i been doing a ton of looking around but found a few problems. 1. in the 4.6 in our trucks are the same motor as the Mustang GTs from 99-04 but front assories are different but not that bad to where a trip to the salvage yard couldnt net you everything you need for cheap. now with that in mind you could in theroy bolt a roots style blower on our truck like a Kenne Bell or Whipple and then just deal with the T-body issue, (wire pull VS drive by wire) wich i have an idea on how to fix as long as you can cut an weld some metal plate.
