Lifted V6, What gears?????
Old Aug 3, 2011 | 02:31 PM
Bshipe22's Avatar
Have a 2007 V6 5 spd with a 3" leveling kit and 33" mud terrains. Really dont know much about geaeing ratios and wondering what gears i should replace my stock with.
Old Aug 3, 2011 | 03:09 PM
f1504x42000's Avatar
as general rule multiply the tire height (33) times (.12) 33x.12=3.96
most people go 1 ratio lower (numerically higher) to make up for putting a heavier wider tire on your truck. the next ratio lower is 4.10
if you were building a trail only truck that never saw the pavement you might go 2 ratios lower to 4.56
Old Aug 3, 2011 | 03:11 PM
Bshipe22's Avatar
Its my daily driver so dont need anything crazy. How would the better gearing benifit?
Old Aug 3, 2011 | 03:20 PM
expedition4x4's Avatar
First off either take off that 3" leveling kit and install a 2.5" kit or do a 6" lift. You're only hurting the truck with that 3".
Old Aug 3, 2011 | 03:21 PM
jam92102's Avatar
Agreed with downgrading to 2.5. 3" is too big and will screw up front end. I would go with 4:10's. That's what I'm going with if I ever get some bigger tires and lift. That way you'll make up for the tire size and give it a little get up and go it didn't have before.
Old Aug 3, 2011 | 03:28 PM
Bshipe22's Avatar
So rough country pretty much talked me into a crappy leveling kit. Why do they offer a 3" kit if its bad. Looking into 2.5 and 4:10 right now
Old Aug 3, 2011 | 04:03 PM
hardrock3742's Avatar
I deliver pizza 40 hours a week in my truck lol
Old Aug 3, 2011 | 07:12 PM
thejake1989's Avatar
You have a 5spd so unless you do alot of highway driving you don't need to do gears and if you do go with 35"s and a 6" lift and 4.10 or 4.30 gears
Old Aug 3, 2011 | 09:44 PM
MossyOak3006's Avatar
I agree with 4.10s and I agree with getting rid of the 3" spacers
Old Aug 4, 2011 | 11:51 AM
if you have 4x4 you can't go with 4:30 ( not available for the front ). if you are going from a stock tire of 28 or 29 i'm guessing, to a 33 tall tire. that is a big difference. you will kill your fuel economy and have a big loss of power. regearing puts you back near the factory fuel economy and engine performance.
Old Aug 4, 2011 | 12:19 PM
True on the 4x4 and no 4.30's but i suggested them cuz im pretty sure his is a 2wd.
but also i ran 35"s with my last truck and before i had gears i was running v6 5 spd with 3.08 gears and my mileage only suffered on the highway. with the manual trans you control the shift points so you not notice the loss as much. on that same note i ran 33"s for a while also with the 3.08s and saw absolutley no power loss but maybe a slight dip in mpg. (went to 4.56 later on the 35"s)
theres really not a pressing issue to regear with 33"s only and a manual trans.
Old Aug 5, 2011 | 03:53 PM
I guess those v6 are more powerfull than I thought. Ive never owned one. an auto eats up a little more hp than a manual right?
Old Aug 5, 2011 | 11:29 PM
yea but its also a shift point issue and the stock gears and big tires confuses the auto trans
