twisted my front shaft in half again!
Find a good drive shaft shop that will build a custom one with thicker wall tubing. Those are pretty big tires on your truck and it seems the d/s is the weak link. But if you are running it that hard be prepared for something else to give up if the new stronger shaft holds up.
You aren't running 4WD on the pavement or other hard surface, are you?
Exactly, I will take a busted drive shaft over the diff any day. You beef that drive shaft be prepared to replace the diff next time out. The drive shaft is the weekest link on purpose. Unfortunatley its the price to pay to play and it looks like you give it hell.
