Major vibration from dead stop to turning
Old Feb 13, 2011 | 11:46 AM
arogers's Avatar
My 2004 FX4 Screw makes a major vibration from standstill to turning in both directions. Only does it if at a stop then turning, not straight on. Its getting much worse over the last several days. The vibration is very noticeably coming from the rear, not up front under my feet like the tranny probably would. What are your thoughts?
Old Feb 13, 2011 | 01:32 PM
Limited slip clutch chatter. Change your rear diff lube, use 75W-140 full synthetic and a bottle of Ford friction modifier.
That assumes you have a limited slip rear.
Old Feb 13, 2011 | 02:20 PM
jgger's Avatar
Also might take about a hundred miles to work in and feel a difference.
Old Feb 14, 2011 | 08:23 PM
arogers's Avatar
Thanks guys! Will change the fluid when I get back in town, as always the info is much appreciated!
Old Feb 14, 2011 | 09:41 PM
tbear853's Avatar
Originally Posted by glc
limited slip clutch chatter. Change your rear diff lube, use 75w-140 full synthetic and a bottle of ford friction modifier.
x 2 !
Old Feb 15, 2011 | 11:59 AM
gibs04's Avatar
Mine started to do that Saturday night along with a clunking coming from the rear axle. Turns out some how I broke the LS cross pin and the pin bolt into 3 pieces.
Old Feb 15, 2011 | 08:26 PM
MTM Ford's Avatar
I just put the Motorcaft Friction Modifier in mine about an hour ago and it seems to have fixed it. Mine started earlier today and was pretty bad a few times, I thought I was going to lose my rear end in no time. Put the modifier in and did about 10 figure 8's and went for a test drive and seems better than ever.
Just make sure you have a flexible funnel when you put it in. It's kind of a PITA.
Old Mar 11, 2011 | 09:09 PM
arogers's Avatar
I put new fluid in about two weeks ago and have put over a 100 miles on her and, it is much better but I still get enough vibration from stop and go turning to slightly vibrate the mirror like I was pumping some bass. Everything looked good and solid when I pulled off the cover, no shavings, metal pieces or anything like I thought I might find. Just really old fluid, not even burnt just old. So any other ideas?
Old Mar 12, 2011 | 11:14 AM
What exact fluid and modifier did you put in?
Old Mar 12, 2011 | 12:21 PM
arogers's Avatar
75W-140 synthetic, I went with Royal Purple mainly because a buddy of mine runs it and keeps yappin about the stuff. I didn't get the Ford friction stuff (and this maybe is where I messed up) the bottles say they already have the friction reducer in them, so I did not buy the reducer. That might be what I should do. I am just ready to say what the heck and dump some in, I don't imagine it could hurt.
Old Mar 12, 2011 | 03:33 PM
Go buy a bottle of the FORD modifier and put it in.
Old Mar 12, 2011 | 08:30 PM
arogers's Avatar
Ford friction modifier is now in. I will report back after a few days. Thanks for the input glc.
Old Mar 29, 2011 | 07:41 PM
ssamme's Avatar
I took mine in last week for a similar problem. The service department said it was clutch packs in the rear diff. It will be about 30 days for parts.
Old Apr 6, 2011 | 11:16 PM
arogers's Avatar
Ssame - Post back when/if they fix it and what they really found once in there. Mine is still doing it, not as bad since the Ford friction modifier was put in. I might dig in and replace the clutch packs this weekend if time permits. Will post up my find if I get to it.
Old Apr 7, 2011 | 08:46 PM
ssamme's Avatar
Will do. I have not got the phone call yet, as soon as it's done i'll let you know.
