What Gears
Old Jan 13, 2011 | 06:31 PM
kitchenboy's Avatar
What Gears
So I'm planning on doing a 4" Rancho lift with 35's and even though alot of people on here with that setup still have there stock gears and dont have a problem, Ive also been told I should put in 456's to avoid trans problems and lag. I do have an Edge which I plan to get custom tunes for to help. That said what is a good brand of gears to get, where is a good place to get them, and what exactly should I be buying except for the Ring and Pinon gears(front and back of course its a 4x4). Also, should I expect to have alot higher rpms on the highway with the 456's. Thanks for any advice.
Old Jan 14, 2011 | 05:26 AM
What gears do you have now?
Old Jan 14, 2011 | 08:29 AM
BAMA_F150's Avatar
Thread jack: I got 3.73s and 37s. I need to regear, but the truck isnt a dog. What are the best gears to get?
Old Jan 14, 2011 | 08:39 AM
With 37's you should get 4.88's.
Old Jan 14, 2011 | 09:36 AM
BAMA_F150's Avatar
I knew that, was wondering motive, yukon etc....
Old Jan 14, 2011 | 09:37 AM
BAMA_F150's Avatar
I didnt make myself really clear in the question lol
Old Jan 14, 2011 | 09:40 AM
BlackOut07's Avatar
Yukon seems to be the best out there for our trucks. Your going to want a master install kit as well. Your rpm's won't be bad, higher yes but with 35's not bad. I'll be running 4.56 with my 33" tires once my s/c goes on if that helps. I've heard randy ring and pinion is a decent place and one or two other places, try search it on the forum I know its been discussed where to buy them, unless someone else chimes in.
Old Jan 14, 2011 | 09:43 AM
BlackOut07's Avatar
Oh diffsonly was another one I think
Old Jan 14, 2011 | 10:00 AM
4.6 Punisher's Avatar
Motives aren't bad, but they do have a tendency to "sing". But if you've got a loud exhaust or aggressive tires, you will hardly hear them.
Old Jan 14, 2011 | 10:11 AM
BlackOut07's Avatar
I was going to suggest motives to him for the price since its 4wd but he said 'best' so I suggested the Yukons.
Old Jan 15, 2011 | 01:01 AM
kitchenboy's Avatar
Yeah I have 373's stock. I think I might do the lift and tires and see how it is first. What is the Master install kit. I only hacve 30,000 on the truck, so I'm not sure I need that kit also.
Old Jan 15, 2011 | 04:25 PM
str8t six's Avatar
i would suggest 4.56's for the 35's.
wayne at diffsonly.com has great prices on yukons.
Old Jan 15, 2011 | 05:11 PM
BLFX4K's Avatar
get the yukons while its cheap! prices are expected to go up
Old Jan 17, 2011 | 02:48 AM
gtdude's Avatar
anyone got a price for the yukons 4.56 for a 4x4? my searching has found many people suggesting diffsonly but im not sure exactly what im looking for.
Old Jan 17, 2011 | 08:15 AM
BLFX4K's Avatar
the yukons will generally run you 300 JUST for the R&P
I was more than happy with waynes quote for both the R&P AND master install kit for the rear of my 4.56
