new shocks?
Old Dec 8, 2010 | 06:42 PM
MuddYMesS's Avatar
new shocks?
ok guys i have completly edited this post. i thought i had it all figured out with the new shocks come to find out i already have diff. shocks up front then in the rear. so bottom line i need new shocks asap. i want something that coould possibly improve the ride of my truck........its a 2000 single cab with torsion key leveling kit and a body life.....please give me some advice as i would like to get these asap
Last edited by MuddYMesS; Dec 9, 2010 at 02:04 AM. Reason: found diff, information
Old Dec 8, 2010 | 06:46 PM
kingfish51's Avatar
By not using the same shock, you could have different return rates which will cause a problem on bumps. With the front at one rate and the rear at another. I have replaced just front or rear in the past and then have at the least a weird feeling going over bumps. I now always do all 4 at the same time. If it were me, I would use the same brand and model of shock.
Old Dec 8, 2010 | 10:04 PM
MuddYMesS's Avatar
well then, i did my research and the sensa trac load adjusting only come for the rear the have a regular sensa trac for the fron though just not load adjusting, is this a setup i should be looking at
Old Dec 8, 2010 | 10:07 PM
MuddYMesS's Avatar
as a matter of fact that will not work because my frony is lifted and the sensatrac only comes in stock configuration. guess ill just get the procomps for the rear also.
Old Dec 9, 2010 | 12:21 AM
Buxton91's Avatar
Personally i wouldnt buy sensa tracs. Have them on mine and theyve sucked since the day i bought them.
Old Dec 9, 2010 | 05:57 PM
MuddYMesS's Avatar
ttp
Old Dec 9, 2010 | 10:16 PM
str8t six's Avatar
bilstiens!
